degree days
ishmael2k
Member Posts: 39
From all appearances the weather service is planning on discontinuing that site.
<A HREF="http://www.weather.gov/view/states.php
">NOAA State Data</A>
Here is a page that will lead you to all kinds of info including degree days by state (Under climate on the list.)
Degree day information
I need some information on degree days for eastern central PA. Is there a site that gives past and present stats? thanks T.0 -
Also
If I'm not mistaken you can also get this info for your area from your local fuel company. A.D.D. for any past 2 monthe should also appear on your fuel bill.0 -
Degree Days
1. Go to Weather Underground,
2. Type zip code of interest into box at upper left and hit enter,
3. Scroll down to "History & Almanac" box and click on "Go" for "Detailed History and Climate" (date doesn't matter yet),
4. Select from "Daily, Weekly, Monthly, Custom",
5. Choose your date range, etc.
Cannot vouch for accuracy of this website, but it has been convenient.
Hope this is useful.
gf0 -
On closer inspection
It seems Weather Underground uses only the simplest method of estimating Degree Days--calculated from extreme temperatures, and apparently, not very accurate.
Discussion of Degree Day Calculations
It seems Weather Underground uses a simple method of estimating Degree Days from extreme temperatures, which may or may not be suitable for your question.
See prior thread: Discussion of Degree Day Calculations
See discussion at earlier thread: Discussion of Degree Day Calculations
It seems Weather Underground uses a simple method of estimating Degree Days from daily extreme temperatures, which may or may not be suitable for your question.
- 86.6K THE MAIN WALL
- 54 Biomass
- 99 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 66 Pipe Deterioration
- 931 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 43 Industry Classes
- 48 Job Opportunities
