Looped heating sytem -zone problem
grayboy
Member Posts: 1
I have a three zone system in my mountain cabin. One zone is not working. The thermostat for that room is not working the wallboard heater.
Should I check the TRV for that loop or the thermostat first?..Not sure where to start!...The other two zones (rooms) work great.
Thank you.
Thank you.
I would
take the head off the valve and see if you get flow (eliminate the mechanical variable at least). If you get flow, break out the multi-meter...0
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
