Plate Installation
ScottMP
ScottMP Member Posts: 5,882
You want as even of spacing between the plates as possible. If you butted against the joist you would have to wide a gap between the two and the next plate would be to close.
I don't know about your area but in my area someof these homes don't really have "uniform spacing" :)
Scott
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=237&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • Joe Furfaro_2
    Joe Furfaro_2 Member Posts: 6
    Plate Installation
    Can you butt the aluminum plates of a radiant staple -up installation along the joist or should there be a bit of floor space between the edge of the plates and joist. i.e. expansion etc.
  • Joe Furfaro_2
    Scott
    Scott, I am keeping an even spacing where it permits, but there are a number of joist spaces that are narrower than most. Butting up against the joist in these cases will give me a more even spacing. I was only concerned if there was an expansion issue to consider with the plate up against the joist.
  • ScottMP
    As long
    as you are a 1/4" off the joist, I don't think you'll get noise but it would be a concern.
    Scott
  • Andrew Hagen (ALH)
    Andrew Hagen (ALH) Member Posts: 165
    I see
    no reason. You're already tightly attaching the plates to the plywood, so the wood of the joist shouldn't be any different.
    -Andrew
  • Joe Furfaro_2
    Thanks for your replies. I think keeping a small distance between the joist and plate will be the way to go.
