continuous circulation
Joe_55
Member Posts: 62
I an installing an 80m munchkin with 60gal. superstor, I've heard of this continuous circulation with mixing valves and outdoor reset control (i have primary/secondary loops with closely spaced tees and circulators) your thoughts on that please
Generally,
Constant circ is self levelling, not needing O.R.
Depending on what valves and what controls, I have always been extremely fond of c.c., with condensing boilers it is a superb strategy - generally. You do not provide enough detail however, to make it a slam-dunk, at least not yet.
I use constant circ
whenever I can on radiant floors. I also use it on cast iron rads. The only time I can think of that it doesnt make sense is hydro air. I'm sure theres more I just can't think of it. WW
Constant Recirc
I am a big fan of constant recirc provided that you have an indoor sensor to fine tune the reset water temp. IMHO, I think that the additional indoor sensor feedback is essential in a well designed high-mass radiant floor heat system. So, it depends on your method of heat transfer. If you are using the reset temp with a hot-water coil and air-handler, it might not be as critical.
Regards,
PR
We alsways have an indoor sensor...
It's called a thermostat (:-o)
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
