copper and steam
ryan_7
Member Posts: 50
What will the problems be with steam lines that were run in copper? Should they be replaced?
Ryan
Ryan
I hope someone answers this because I just noticed when they put in the new (10 yrs ago)steam furnace (2 pipe system) they used about 2 ft. 2" copper to connect output to older pipe and about 4 ft 2" to older return pipe.0 -
copper
i have seen copper on steam , both headers & returns last 25 + years and still going strong. low press. , residential0 -
How Long...
... are the boilers lasting?0 -
The problem with copper on steam
is that it expands more than steel. This can cause the soldered joints to break and leak. That's why I always do my steam piping in black steel. Yes, I've seen some copper headers that weren't leaking....yet.
On a wet return which will never have steam in it, IMHO copper is fine. If the water quality is such that it would attack dissimilar metals, you can use dielectric unions.0
