different size pex's
SWS2_3
Member Posts: 3
Anyone have any experiennce with mixing tubing sizes on the same manifold? Looking at a few 5/16" for quik-trac and a few 1/2" for an undrfloor area. Better off with 2 manifolds / circs??
I would think it would be tough to balance, but if you do the math and you're careful with loop lengths.. and have balancing valves... it should be doable.0 -
well *~/:) funny you should ask :
did you think of using some 3/8ths and the 5/16ths ? they are a bit more closely related.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 69 Pipe Deterioration
- 949 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
