Buderus GB142 Set Back
Big Ed
Member Posts: 1,117
What I understand The GB142 does not have a room temperature set back. Is this correct ? And if so to add one with the room sensor What is the best way to do this ? I read on a post, that I need to control the system circulator (thermo and relay) ? Is this correct ? Seems odd , wouldn't the boiler still burn ?
I guess I could use a clock therm to TT but then I could not use the nifty room sensor ?? Why not built in set back ? Seems odd to leave out......Is this a Euro thing?
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 69 Pipe Deterioration
- 949 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
