Taco 00 Circulator O-Ring or Gasket
Norm Harvey
Member Posts: 684
I prefer the black rubber full flange gasket. The red rubber tends to harden and crack over time which make it near impossible to remove.
Why am I not a fan of the O ring type gaskets?
I've never had a black rubber fullflange gasket leak, but I have seen many of the O ring type do so.
I think they cost around $1.00 and I see it as a good investment.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=395&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Taco 00 Circulator O-Ring or Gasket/Which do you prefer.
The Taco 00 circulator comes with 2 O-rings as most of us know. Many oil repair people replace those with the flat red gaskets when there is a leak at the flange. I prefer to clean out the old O-ring and install new Taco O-rings. Can I get people's preferences and why?0 -
We use both the taco black o rings and the red rubber full flange gaskets. Just a little added protection.0
- 87.8K THE MAIN WALL
- 130 Chimneys & Flues
