metzger warm air furnace
Steamhead (in transit)
Member Posts: 6,688
to get these parts from Beckett. Do you have the Beckett OEM Spec guide? The air tube assembly number is in there (not sure if the head and heat shield are available separately) as well as the proper setup info.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=367&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
parts for a metzger warm air furnace
I am having a hard time finding a replacement airtube for a mid '90s metzger w/a furnace it has a beckett afg burner and it burns at 1.00 gal/hour the retention head was completly destroyed and the serial and model #s are illegible the air tube is stainless steel with a ceramic heat shield installed behind the retention head The tube is fine but the retention head is gone and the ceramic ring is broke any help appreciated thanks Tom0
- 120 Geothermal
