room temp never goes above 72. 2 zone hot water system
Shane_2
Shane_2 Member Posts: 198
This is terrible news, I really liked the Garmin girl with the accent while I was driving.
Shane F
  • Bill_92
    Bill_92 Member Posts: 1
    low heat
    I have 2 zone hot water heat. Temperature of house will not go above 72 no matter how high thermostat is set. Both thermos are fine and I never had this problem before.
  • 72 *not enough?
    Do you have outdoor reset too? Perhaps the way it`s set-up, it wont allow any warmer temps.
    Dave
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    Efficiency Chip
    A special radio frequency activated chip has been inserted into every electronic control board and electronic thermostat ever made. It prevents highly wasteful settings.
    They all woke up when the daylight savings period was changed.
    Special blocking devices will soon be available by prescription from your doctor.
  • Shane_2
    Chips
    Hey, Is that why my F350 won't get above 90 on the highway anymore? Darn H. E. Chips
    Shane F
    Control for that comes from GPS satellites.
  • Jim_65
    Jim_65 Member Posts: 184
    Comfort
    I think the question is "Are you comfortable?"
    Or do you have to see the temperature on the thermostat to make you feel comfortable?
    I would be in shorts if I kept my house that warm. :)
  • ANDREW_12
    ANDREW_12 Member Posts: 29
    bill
    Is there anything new about your system, are the termostats new, and level? Is your boiler continuing to run constantly or is it shuting off on tempature? If so have you just added new baseboard to the zones? As state below, 72 degrees is normaly very warm, unless you are very old or very sick, is this a comfort question?
    Andrew
    Knowledgeable P & H
    Northern NJ
  • Mad Dog!!!!!!!!
    Mad Dog!!!!!!!! Member Posts: 157
    and.....whats the problem?????
    did you expect tropical temps? If your home can maintain that in the coldest weather, you have a competent system I'd say. Mad Dog
  • bill nye_3
    bill nye_3 Member Posts: 307
    Temperature?
    What is your boiler water temperature? Did someone turn it down?
  • allenleo
    allenleo Member Posts: 26
    what what what
    are you trying to get to 72.3 degrees, what is your target temperature ? what kind of controls does this system use to limit operating temperatures. are they set correctly for what you are trying to achieve ? are you sure your thermostats are accurate and in good working order ? if you say yes, how do you know ? was there any alterations to the system at all, or any alterations to the house ? are you using zone valves or circulators to control the flow ? are they working properly ? if you say yes, how do you know ? is this gas or oil ? if its gas, is there enough pressure to the gas valve ? if it is oil, is there sufficient oil flow through the nozzle, was it underfired recently or at the last tune-up ? answer these questions and you will solve your problem or at least find out what the problem is . allen leo.
  • Weezbo
    Weezbo Member Posts: 6,231
    Before?
    Before WHAT?
