Teflon tape use
Concerned Apartment Owner
Member Posts: 47
I recently had the thermostatic disc replaced in a horizontal steam trap. Building engineer used teflon tape around the threads of the trap cap. The trap never worked right after that. I only found this our after having a brand new trap installed and saw the teflon tape hanging out the drain side of the trap. Questions: 1)Is it standard practice to use teflon tape on the cap threads of a steam trap? 2)Is it possible for the tape to prevent a new disc from functioning properly? Should I have the rest of the trap caps in my apartment?
\"Maybe\"
I have virtually no steam experience, but I would say that if you get enough teflon where it shouldn't be maybe it could keep things from moving like they should. I'm sure someone with steam experience will chime in here. Kevin0 -
see this artical in hot tech topics:
http://www.heatinghelp.com/newsletter.cfm?Id=102
Answers your question directly.0 -
Yep, it does answer my questions...
Thanks for you help.0 -
teflon.
if the teflon is used carefully by a competent mechanic there should not be any problem. when he saw it was not working correctly ,did he take it apart & check it ? probably not. there are mechanics and there are also rudy the repairman's . i personally seldom use teflon but it can work if used properly.0 -
Give me a kiss
Using tape on the cover of a trap is wrong and totally useless. That's why, while trying you probably ended having so much tape that it bunged up your orifice.
The thread on the cover is straight, hence neither tape nor dope can work. The seal is made on the little lip. Some traps have o-rings here.
To get a tight fit, work with very clean lips for which you need an oil stone, particularly if there are tooth marks left all around.
What's more, any extra gasketing material on that lip will change the operating distance on the bellow (if it is indeed attached to the cover) and possibly prevent normal operation.
1) no; 2) yes; properly operating traps is THE key to energy efficient operation, so yes, plan on giving your traps a new inspection
teffy on trap heads
Just one word to solve your problem......never-seize!!!!
Amazing.. Thanks for the insight folks
- 87K THE MAIN WALL
- 57 Biomass
- 426 Carbon Monoxide Awareness
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 990 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
