Mouat Trap- remove tailpiece
I'd like to temporarily convert a radiator to one pipe. (return froze & split, have not yet been able to repair, supply is 1 1/2" riser with no other radiators on line)
Do the Mouat (pat'd Oct. 18, ___ ) tail pieces have an internal removal pattern (for lack of a better word)? If so, can a common tool be used? I can't see into radiator opening (outlet) as radiator is in a cabinet. If I recollect correctly, does it look something like the B & J tailpiece?
Attached should help identify.
