X - Pump Block
Wayco Wayne_2
Member Posts: 2,479
going to use it to draw heat out of a gas water heater to supply a radiant floor for an addition. It needs 12000 btu's at 10 degrees outside temp. Should be a good fit for this application. WW
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=255&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Has anyone
used Taco's X pump Block yet. I saw it at Rad fest East and want to consifer using it on a job I just got. WW
Pump block
Used 3 so far, in general a pretty good way to add a small radiant zone to an existing boiler. Good luck so far. Tim.0 -
about a mont or two ago....
Paul posted an X-block and i cant find the post:(
do you need some tech data ? taco has a new Wizard for looking stuff up...and they have a cool program Free sorta like hydronic cad called Taco Load Match, i asked them this summer if they had added the pump block i series S and R and the X block...nope. however i think it is an option that can be imported into the system. the load match deal is to aid in sizing pipes flow pumps X changers boiler on and on really a quick study not quite as quick a learning curve as the Hydronicad though ,colourful never the less.
are you into using it for a coil ? it has three Modes like the pump block delta t outdoor and set point. man i am tired as heck lately....0
- 86.7K THE MAIN WALL
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 939 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
