Determining baseboard needs
Brad White_9
Member Posts: 2,440
and obtain your heat loss, divide that number by the rating in BTUH per linear foot of your chosen baseboard style and at the average water temperature you will be running.
Then you will know at a minimum how many linear feet you will need. Easy!
Just lay it out along exterior walls and concentrate element below glass first. Go onto interior rooms only once the exterior walls are covered. Cool.
Is there a formula to calculate linear feet of radiant baseboard needed for a particular room size or volume?? How is this figured out?0 -
Click on
Heat Loss Calcs on the navigation bar and get the free CD-ROM from Slant/Fin.Retired and loving it.0
- 125 Chimneys & Flues
- 120 Geothermal
