Noisy steam pipes
Steamhead (in transit)
Member Posts: 6,688
of the expanding pipe rubbing against something. Nothing to worry about.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=367&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Noisy steam pipes
I'm having a problem with a verticle pipe that feeds the furtherest radiator in my house.(Second Floor) when the heat comes on ,after a few minutes i hear a loud ticking noise in this particular pipe which is located in the bedroom wall.I checked the radiator and it seems to be pitched correctly but i did notice that there is no shut off valve on the pipe going to the radiator.Don't know if this could be causing a problem.Thank you for any advice.
- 87.5K THE MAIN WALL
- 122 Chimneys & Flues
- 118 Geothermal
- 15.9K Strictly Steam
- 57 Water Quality
