Bad Barrier
Ted_8
Member Posts: 31
Anyone else seeing Uponor PEX with bad barrier? I had two rolls of 3/8 last month that were very rough and peeling in places and now have a roll of 5/16 that has large bumps in it and looks as though it has some sort of debris in the coating. Are they having quality control issues or is it just my crappy luck?
Chris
Chris
Bubbles
I have seen other brands of tubing with bubbles (some were large) that appeared to be in the EVOH coating.0 -
The peeling may be because of a handling error. Maybe it was kept outside for too long or stored somewhere it shouldnt have been. As for the bumps, that could be any number of things from debris in the extruder to bad resin. Uponor's pipe usually isnt the smoothest most consistant pipe but it shouldnt have bumps, i would def. return that pipe, especially because it may cause problems going into their panels.0 -
two thoughts...
Back to back! *~/:)
sorry little bit tired and basically delerious frome lack of sleep
one thought is, i have seen some 1/2" that had bumps wverly waves clear spots...thing to do is go in and immediately get the wholesaler to exchange it yet more importantly get them to notify the Wirsbo crowd that way they can quick check the records of the quality control ...then that helps everyone else further down the line.
second thought goes like this..throw the pex in the back of the truck...well Now... my muffler goes thru the bed of the truck and terminate out the top of the pipe rack...that tubing got a severs case of Radiant heat
- 120 Geothermal
