4 way mixing valves
Ted_9
Member Posts: 1,718
I recently noticed that Buderus shows a circulator on the return back to the boiler, leaving the 4 way. Viessmann does not. I believe the controls act very similar in these instances so why the difference?
Massachusetts
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=373&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Massachusetts
My guess is
it makes no difference. The 4-way is at once a mixing and diverting valve. I have seen Centra (Honeywell) systems set up both ways both in the field and diagrammed."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 114 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 49 Job Opportunities
