Inner Workings of a Tiger-loop
Ken_40
Member Posts: 1,310
Tigers.
Lots of them.
Kidding aside, the large float and relatively small orifice the float "boss" seals, when in the "down" position, allows circulation.
When the float "floats" (lifts), it uncorks the boss and allows vacuum to suck fuel, bypassing the re-circ action when the float was formerly down.
Look a it carefully. air vent atop. float. guide shaft, lower boss that "seals a tiny opening directly under the boss (which acts like a stopper. Ingenious, but simple.
Lots of them.
Tiger-Loop
What is the mechanics of a Tiger-Loop ? Seems like at first start up it pulls right from the tank and once it collects some oil in the reservoir , it will circulate around the loop and only pull from the tank what is needed to burn . I would like to open one up some day . Anyone know what is inside ?0 -
Simple machines always work the best . Thanks Ken for scratching the itch ,0
- 87.5K THE MAIN WALL
- 118 Geothermal
- 394 Solar
- 15.9K Strictly Steam
- 50 Industry Classes
