Brumell steam vapor system
info in the library section of this site.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=360&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
gwgillplumbingandheating.com
Broomell vapor steam system Help me Dan
I am a contractor and have a customer with this system, which to be honest have never seen before [just read recently read about in one of Dan's books]. The owner just bought this house so I don't know any past history of it.The boiler is 5 years old [has some minor near boiler piping issues I'm already aware of],the house only seems to heat the inside radiators, front and back of the house don't heat. All the radiators seem original with broomell valves and broomell return I believe there called p traps.The system has the condensing radiator in the ceiling and it's not piped to the chimney anymore, currently into a f/t trap with a lone main vent. All broomell controls at the boiler have been removed. It currently has a pressuretrol not a vaportrol and is set cutout 3psi.Any advice on the next step, can this system be modified? Should I put in a vaporststat? Should I pipe the condensate radiator back[is this a must?] to the chimney without the Broomell controls at the boiler? I know its a ton of questions but I hope someone else ran across a ruined brumell system and was able to either re-engineer something or correct the existing system.Thank You sorry for the length of the question.0 -
Broomell System
Is there anyone in your area that knows Steam? Have you tried the "Find a Professional" link?
Not \"ruined\"
just "knuckleheaded". This can be fixed. I suspect the air can't get out of the system.
"Gordo" (above poster) is my partner in All Steamed Up, Inc. and I'll second his recommendation to get a real steam pro in there to consult with you. If you're in the Baltimore area, get in touch with us. If not, where are you located?
Chicago0 -
Get in touch with Dave a.k.a. Boilerpro
he's a Vapor expert, located in Amboy but might be persuaded to come to Chicago for a Broomell. His company is called Boiler Professionals, follow the link below to see his Find a Professional ad:
http://www.heatinghelp.com/getListed.cfm?id=393&Step=30
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
