Taco zvc
J.C.A._3
Member Posts: 2,980
What is the control calling from the indirect?
Just thinking out loud here. Chris
I had a strange...
occurance happen today...I have had a working heat job installed for two months(zone 1 and 2) uses HW zv and a taco zvc 403. I go to hook up the indirect today and when I hook up the t-stat the 3a fuse blows... disconnect 4 wires and only the t-stat hooked up amber ligt glows..no problem...can a bad Zv cause an overload? After talking w/a tech @ taco he said the board was bad...changed it out...same thing. I have checked al the wiring and have no shorts...any thoughts. ty, kpc
Why
not use a SR-501 and a separate 40VA transformer? I use this with a L6006 on the indirect for priority
The water heater
is a Super stor contender. It has a bi-metal surface aquastat.If I jump out tt at the zone control there is no problem...I have a Honeywell zone valve controlling flow to the indirect.kpc
wire
I had a bad batch of 18/3 once that drove me nuts. I had intermittant shorts. Ohm out the wires and look for shorts in the thermostat wiring.
Worth a shot anyway
Cosmo0 -
you are right...
at 5:15 I really was not up to doing that....I will give it a shot.
