vacuum condensate return
I have a jennings "vacuum heating pump' which has 2 condensate pumps and 2 hurling pumps. The system will not make a vacuum. Any help is greatly appreciated. The system worked great for the last 60 years.dom..
  • Noel
    Noel Posts: 177
    won't make vacuum
    Assuming that the pump and controls operate, what is the return temperature as it enters the tank?
    Noel
  • FredR
    FredR Posts: 62
    1-Does the tank have enough water for the (hurling) air pumps?
    2- Are return lines leaking? Sucking sound if air pumps work and water leakage when air pumps are off.
  • Check seals
    and water level as noted. After 60 years, everyone has a leak problem it is written... I saw one years ago with a nice neat hole between the hurling tank and the main tank, just rotted out in a spot for reasons unknown but it was a steel tank, not CI. Can you check tank integrity?
