Four-way mixing valve
Ted_9
Member Posts: 1,718
I like using the Buderus mix station, everything is there. But we do use the Taco 3 way I series valves quite often.
Massachusetts
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=373&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Massachusetts
Four-Way Mixing Valve
I've been shopping around for a four-way mixing valve for my heating system and got into some sticker shock with some of them, particularly larger, bronze units.
This morning I happened upon a Honeywell Corona, which is a cast-iron 1.25-inch valve that retails for around $60. The motor is another $100. My piping on the zone in question is 1.25-inch copper.
That's a fraction of what I expected to pay.
Am I missing something?
Here's the link:
http://customer.honeywell.com/honeywell/ProductInfo.aspx/V5442N10310 -
try
The i-series valve from Taco.
I think they are well priced.
http://taco-hvac.com/en/products/i+Series®+Mixing+Valves/products.html?current_category=1880 -
I would Highly...
second that...used one two months back....very happy.
try to actually buy one
I checked out the Taco website, but I couldn't find any of the 1.25-inch models for sale online. Do they make a cast-iron model?0 -
Check out buderus.net They carry a complete line of mixing valves, motors and mixing stations.
A 1.25" pipe will only need a 1" mix valve because of the temp difference. An oversized valve will hunt.0 -
no, but tekmar does up to 4\" - not cheap though
016 - valves
http://www.tekmarcontrols.com/literature/acrobat/d016.pdf
011 motor
http://www.tekmarcontrols.com/literature/acrobat/d011.pdf0 -
you need to...
go through a supply house. Model # i125T4R-1...
if you want setpoint control change the R to S.
And it is brass not CI.kpc
- 119 Chimneys & Flues
- 114 Geothermal
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
