control wiring question for zone valve
carol_3
Member Posts: 397
I'd go with a zone panel that will help you get everything wired into where it needs to be. Taco's is quite popular, and should be compatible with your Taco valves. Honeywell has a new one--don't know if it's out yet.
how to wire controls
HI, I'm new at this and installing my own multizone system with 8 zones valves and one single speed circulator on the supply manifold and one single speed circulator on the boiler closely spaced into the return manifold. The valves are Taco 3 terminal, 2 wire 570 series with end switches. What type of switching relay block do I need to wire the zone valves, pumps, and thermostats? Thanks, this is a great website!0
