Boiler maybe damaged from flood
Alan_15
Member Posts: 2
Thanks for your reply. The heat is coming up. The radiators are now nice and toastie. I will have it checked.
Hello this my first time posting here. I recently had a flood. I was able to start the hot water heater fine. The pilot light for the Weil-Mclain Boiler goes on. But the valve clicks and sometimes the flame starts and then goes out. I hear the valve click a couple of times and hen stop and then click again. I am thinking that the valve needs to be replaced. What do you think? Thanks0 -
Call a pro
> think? Thanks
to replace any control that got submerged, and inspect the rest of the unit to see if it's safe to operate.
Call a pro
Read this
http://167.236.208.124/professionals/services/Bulletins/SB0001.pdf
This is a bulletin from WM that deals with your situation.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
