Design Only Service for Hot Water Radiator System?
Hello
Can someone recommend a service that can do the design portion of a hot water radiator system for my small home? Radiator sizing, boiler sizing and a detailed supply list along with precise plans is all I would need. I have received two stratospheric bids for the design and supplies (boiler, radiators, etc) of a system. These are from internet companies. While I feel they are not attempting a rip off I do feel they are trying to sell the most expensive complicated system and are taking advantage of my unfamiliarity with this type of heating. I have considerable construction experience so while I do not completely understand the exact details of the boiler to radiator plumbing hookup I can conclude that the prices proposed are not necessary to do the job.
Thank You
Scott
  • kevin coppinger_4
    kevin coppinger_4 Member Posts: 2,124
    where are you?
    have you thought about working w/ a local contractor to help you? kpc
  • John@Reliable_14
    John@Reliable_14 Member Posts: 171
    Why don't you involve a ...................
    local company? "Precise plans" are rare with replacement systems. Work with a local guy, that may let you do some of it. You also said "taking advantage of my unfamiliarity with this type of heating" You really need a pro's help, and I bet it will work better from someone who understands the local conditions. Did you check "Find a pro" here?
  • Scott Gordon
    Scott Gordon Member Posts: 6
    It is actually going to be a new system in a home that used to have forced air which has been removed. I live in a relatively isolated community and there are no professionals that do this type of system, believe me I have looked. Forced air is king here. Find a professional had nothing for my area. I realize that many in this forum are pros but I would like to do the install myself.
  • kevin coppinger_4
    where are...
    you...someone here might just know someone nearby....kpc
  • Jeff Lawrence_25
    Jeff Lawrence_25 Member Posts: 746
    Like Kevin said
    Where are you? There could be some hidden gems in your area.
    Jeff
    Woodstock, Georgia
  • Norm Harvey
    Norm Harvey Member Posts: 684
    Manufcturers of equipment are a great resource,.. decide what kind of equipment you want to install and contact them. The manufacturer should be able to refer you to someone, or help in the process themselves.
    Whats the scope of your project?
  • Brad White
    Brad White Member Posts: 2,399
    Designers and Engineers
    Most single-family up to 3-family homes do not require a P.E. stamp but some jurisdictions may require it for their own liability.
    Still, you may want to call any small engineering company in your area; they may be willing to take it on. Siggy (John Siegenthaler) at HydronicPros.com is a NY registered P.E. and offers design services with a stated minimum charge.
    Where are you located?
    I do this kind of work but will decline it as I do not use this forum to solicit paying work. But there are folks out there.
    -Ernie White, my Dad
