Hot water Problem
John@Reliable_14
Member Posts: 171
1.) underfired 2.) Heatexchanger dirty 3.) Coil needs replacement ( if over 10 years old ) 4.)Shower valve. Just to name afew, hope this helps John@Reliable
hot water problems
I have an oil fired boiler and in the winter months I have to let the shower run for at least ten minutes just to take a warm shower. I have an extra zone off of the boiler that I am not using should I install a hot water heater. Is this my only option or is there other means to get hot water.0 -
do you have a tankless coil? If so, you're probably taking a shower while there is a call for heat. Adding an indirect w/ a priority relay will probably help you out. You just have to look at the tank literature & see if you have enough boiler to get the published recovery of the tank.0
- 87.5K THE MAIN WALL
- 119 Geothermal
- 394 Solar
- 15.9K Strictly Steam
- 50 Industry Classes
