In-floor controls
Alan(CaliforniaRadiant)Forbes
Member Posts: 1,243
good luck with ESBE mixing valves and a TC62 controller available at Paxton:
http://www.paxtoncorp.com/rv.html
Make sure you get the brass mixing valve (top picture) and NOT the steel one (bottom picture). The steel ones seize up after about a year.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=53&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
In-floor controls
Does anyone out there have a preference on controlling a 3-way valve for an in-floor heat system? Heat Timer used to make just for in floor but they have stopped making that unit.
Any recommendations?
Thanks in advance!
Bill Glynn
Monroe Mechanical
3 or 4 way
the 3 way is good for condensing boilers bu use a 4 way with a sensor on the return to protect the boiler if its not rated for condensing system0 -
tekmar 360 Mixing Control
visit www.tekmarcontrols.com or call the office at 250-545-7749, Ext. 214, should you have further questions or comments.
Regards,
Mike0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
