Heat transfer rates for different metals
Ross_7
Ross_7 Member Posts: 577
I realize that. I just meant it was a good reference that's all. Thanks for the input
  • Ross_7
    Heat transfer rates
    Hello fellow wallies,
    I seem to remember a chart posted here quite some time ago, with metals like cast iron, aluminum, copper, and steel, with the heat transfer rates. This is a good reference for use of different types of boilers. Does anyone have a copy of this or a resonable facsimile? Thanks in advance
  • Ross_7
    Hello?
    Hello?
  • Tim Doran
    Tim Doran Member Posts: 208
    ASHRAE Fundamentals
    Check this handbook out. It has a chapter on the physical properties of materials.
    Tim D.
  • Ross_7
    Ok...
    Thanks Tim..I'll look into it.
  • ALH_4
    ALH_4 Member Posts: 1,790
    Try
    MatWeb.
    Just because copper has high thermal conductivity doesn't necessarily mean we should all have coppe fin tube boilers. Stainless steel is a poor conductor of heat relative to aluminum or copper, but other properties make it very appealing. Also thickness is important. Aluminum generally is much thicker than stainless steel heat exchangers.
    -Andrew
