Mini duct Air Handlers
will smith_4
will smith_4 Member Posts: 259
And get ready for some sticker shock with ANY of the high velocity type systems. They are great for certain applications where standard duct can't be run, but the material cost is pretty salty!
  • Mark_46
    Mark_46 Member Posts: 312
    Mini ducts air handlers, furnaces and compressors
    Hello all,
    I have begun to research replacing our steam gas heating system but would like to add central A/C at the same time.
    I have myself partially convinced that the most cost effective way to go about this is to switch to forced air where the duct work can be used for both heating and cooling. This avoids having 2 separate "circuits"....eg pipes/radiatiors for hot water heat and ducts for cooling.
    So, I like the mini duct air handlers from either Spacepak or Unico. Spacepak claims their blower units can be used for heat as well by adding a hot water coil. Assuming this, what furnaces would work well? Which AC Compressors?
  • ed wallace
    ed wallace Member Posts: 1,612
    mini duct
    stay with steam heat its more comfortable no drafts just do mini duct for a/c
  • tom_49
    tom_49 Member Posts: 267
    Go Unico for a/c only. Good quality.
    Like Will said , the equipment is pricey, but when its 100o and humid and your house is 72o and dry, you'll have forgotten all about the price.
  • John Taylor_2
    John Taylor_2 Member Posts: 12
    Unico
    I would also agree with the others. Steam heat and Unico for cooling only is the best of both worlds.
    Unico allows the use of a round, steel duct system that is then insulated on the exterior which keeps the air stream from being exposed to fiberglass. It will also have less energy losses in an attic installation than a conventional duct system due to it's reduced duct sizes and the ease of sealing and properly insulating.
    You'll have to search out a contractor who is willing to use steel duct as most I believe go with the fibrglass ductwork. Also make sure a proper heat gain is done and that the duct system is properly engineered using the room-room data.
    John T.
  • Bob Forand
    Bob Forand Member Posts: 305
    Unico also has hot water coils...
