Scorcher cycling on limit
Larry F
Member Posts: 25
A possible exception to the rule; "If no air comes out, it ain't an air problem"
I've seen undersized returns before but dang. The vertical flex run is connected to a 4x10 floor register...with damper closed. We don't use that one no heat comes out. The second flex run winds back along the floor and not connected to anything. Just lays there and brings basement air to the living space. 2006 promises to be every bit as interesting as '05.
- 86.6K THE MAIN WALL
- 54 Biomass
- 99 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 66 Pipe Deterioration
- 931 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 43 Industry Classes
- 48 Job Opportunities
