Radiant bathroom floor from single pipe steam
PM_2
Member Posts: 38
I thought so, tell me where to get diagams and flow rates etc.
Grandma's new bathroom
Grandma is getting a new bathroom. I'd like to put hydronic radiant in the floor but the only heat source is a boiler/single pipe steam. What is the best way to create 110 deg F water? What books should I read?
PS DHW is gas fired.0 -
magic
to do radiant with one pipe steam you could use a book on magic. don't think it can work0 -
I know there are ways to heat DHW with a steam boiler, this can't be too different.0 -
dedicated loop
you could run a condensate loop circuit w/ pump,controls,piping, bypass etc. i thought you wanted to use the existing steam branch as a source. you are correct , its no big deal. a hour or two work & a few bucks for material. get on it ,you will enjoy it.0 -
Electric
Electric may work well here.
electric
Yeah, I know. But she keeps the house 76 degrees all winter, and I'm much more concerned about the monthly cost than the install cost.
You ever notice that the house is t-shirt and shorts temp all year and grandma complains that all anyone does when they come over is take a nap?0 -
Go to the upper left menu and click on Heating Q&A. Then click on condensate hot water heating. That will get you to designing a hot water loop. Then ask the pros here how you get from there to the radiant temps you desire. I'll be interested in their answer as well.0 -
Thanks, Got it. Easy really.
If the rest of the house is quite warm and the bath doesn't have a lot of glass/exposed walls, and it's not too large, and your electric isn't ridiculously expensive then I'd go with the electric. Easy to control and quite inexpensive to install. Just make certain you get a floor temp sensing controller.0
- 86.5K THE MAIN WALL
- 53 Biomass
- 95 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
