Fulton Pulse Boiler
Jason Grossman_2
Member Posts: 2
I have a Fulton Pulse Boiler that has had the gas orifice fall out twice. It is a 2" brass plug with holes drilled in it located inside the combustion chamber. Does anyone know what may be causing this and how toi stop it. Combustion analysis is good and boiler is reliable for about a month after reinstalling the orifice.
Pulse Orifice
Jason,
I have read your question. If you could give me a call at 315-298-7148 I will see what I can do to get you the answers you are looking for. I would need the model number, national board number, and state the unit is installed in at the time you call.
Regards,
Scott Redden
Fulton Companies
Service Department0
- 86.9K THE MAIN WALL
- 57 Biomass
- 109 Chimneys & Flues
- 5.7K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 975 Plumbing
- 6.3K Radiant Heating
- 386 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
