Steam Air Vent Sizes: Standard From All Manufacturers?
Hitzkup
Member Posts: 63
check out this link. you will find an answer to all your questions http://www.heatinghelp.com/shopcart/product.cfm?category=2-138
mark sch
mark sch
Are Radiator Vent Sizes Standardized?
Do steam air vents from different manufacturers with the same size designation vent at the same rate?
i.e. Sizes 4, 5, 6, C, D
- Also, which of the above sizes would a Hoffman 40 be equivilent to?
- How about a 70A while were at it?
- The Hoffman 1A adjustable vent is listed as being adjustable from sizes 1 to 6. Are the 4, 5, and 6 settings of the 1A comparable in air flow to the 4,5, and 6 of other manufacturers? If so, how come some other manufacturers don't make sizes 1, 2, and 3? (I haven't seen them at least.)0 -
May I ask a question here,? Are some brands considered better than others? Hoffman, Vent-rites, Grotons etc.?0 -
Quality...
Gortons and Hoffmans are the best and will last for a long time. Heat-timers are excellent, but don't last a well.
Anything Chinese is garbage and doesn't work.
Long Beach Ed
Thanks0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
