outside air condensing
Brad White_20
Member Posts: 13
wrapping the OA duct with foil-faced fiberglass insulation and sealing the vapor barrier. Rocky is right- something is going to sweat and you found it!
Has anyone had trouble with an outside air supply to an oil burner condensing. I'm refering to the kits that go directly to the burner.0 -
Yes, several, in fact
Yes, several in fact
Have one right now on a Buderus 115-21 with the balanced flue application. The condensate is running right down the inside wall of the boiler room from the cold outer shell of the venting kit. Don't really know how to get away from it. Twenty below air and a 75 degree boiler room...well...somethings gonna sweat.0
- 86.6K THE MAIN WALL
- 54 Biomass
- 99 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 66 Pipe Deterioration
- 931 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 43 Industry Classes
- 48 Job Opportunities
