Water feeders adjustable?
brucewo1b
Member Posts: 638
http://www.wattsreg.com/pdf/1910265.pdf
Are the standard residential style Watts water feeders adjustable for pressure? I've got one that seems to be over feeding but is only 1 yr old. The piping is set up right w/ the feed at the pressure tank and all the circs on the supply. Just wondering if you can unscrew the fast-fill and back off the spring loaded pushrod. Anyone tried this or do I junk it? Thx0 -
it may be your expansion tank or a leak in the domestic coil --or exchanger if you heat domestic with the boiler system water --you can close off the feeder to test it --0
- 86.5K THE MAIN WALL
- 53 Biomass
- 95 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
