Potential pump problem
John_88
Member Posts: 8
Series 100 pump when running has a hesistation in it that more than likely caused the destruction of the pcast iron coupler
Pump is two years old?
Any ideas causing the hesistation?
was it oiled
when installed? Sounds like the bearing are seizing up. 3 oil cups, a few drops each on the motor, the rest of the plastic vial in the bearing wicking.
Or something stuck in the impeller, solder, stones, copper reamings, etc.
hot rod
Spring coupler
A common cause of premature wear is misalignment of the motor itself. Motor mounts eventually wear and out of wack causing stress on the coupler. Also, as Matt stated it is very important that the pump be oiled upon start up as to the manufacturers reccomendations. If it was under oiled, especially the bearing assy, the damage is already done.0 -
Taco pumps are pre lubricated
sounds like the B&G coupler that failed. Taco uses a spring type coupler.
Joe Mattiello
Technical Support Technician
Tel. 401-942-8000 X 484
Fax. 401-942-2360
1160 Cranston St
Cranston, RI 02920
joemat@taco-hvac.com0
- 87.5K THE MAIN WALL
- 123 Chimneys & Flues
- 118 Geothermal
- 15.9K Strictly Steam
- 57 Water Quality
