Maid-O-Mist valves
Is it me or are the maid o mist valves crap? I went thru 3 new ones when i tighten it just a little it breaks and just keeps spinning and spinning and it doesn't want to tighten.
  • Mad Dog_2
    Mad Dog_2 Member Posts: 7,519
    No comment ED...................................................
    I've used them ALL. There is none better than Gorton and Hoffmans. I prefer Gortons main vents for capacity. Mad Dog
  • Robert O'Connor_3
    Robert O'Connor_3 Member Posts: 272
    Home depot doesnt carry those. Do you know if Lowes carries them or do I need to go to a local plumbing supply store?
  • Lurker_2
    Lurker_2 Member Posts: 123
    local supply store
    Home Depot/Lowes doesn't carry them as far as I know. You can try www.pexsupply.com. I bought stuff from there and usually get it on the next day, though of course their warehouse isn't very far away.
    -Michael
  • Pete_18
    Pete_18 Member Posts: 197
    good vents
    Good vents cannot be purchased at HD/Lowes. You must go to a good plumbing supply store, and even then, you may not find them. Gortons are the preferred choice by the experts. I've had very good luck with them myself.
  • chuck_6
    chuck_6 Member Posts: 107
    Use Gorton vents
    Ed:
    Listen to Mad Dog and go with the Gorton vents. I have Gorton main vents and radiator vents and they work great.
    Look up heating/plumbing supply stores nearby. You can also call Ken Kunz at Gorton at (908) 276-1323. He can walk you through venting.
    Chuck
  • Marty_7
    Marty_7 Member Posts: 30
    try www.patriot-supply.com they have good prices and excellent service
  • Ryan_10
    Ryan_10 Member Posts: 26
    Is there really...
    a big difference between the M-o-M and Gorton's as far as the radiator vents are concerned other than the float? I just bought a bunch of M-o-M vents and they seem to work fine and flow well. My only complaint is some whistling, but for $7 I don't care.
    Do Gorton's not whistle at all? I picked up a bunch of Heat-Timer's at the same time, and those are just in another league altogether. Remarkably high quality and a very smart design, IMO.
  • Ryan_10
    For what?
    All they have is Hoffman ... which seem overpriced to me.
  • Robert O'Connor_3
    i found hoffmans at Ace Hardware. Got 3 there. good prices too
  • Robert O'Connor_3
    I know the M o M's are made with 2 pieces. So far both pieces got loose on a few of mine, not air tight anymore. Aren't the Gortons made from one Solid piece?
  • gerry gill
    gerry gill Member Posts: 3,078
    the hoffmans
    don't vent anywhere near as fast as the gortons do..the faster you get the air out..the faster the steam gets in..the faster the thermostat gets happy..the faster you can close your wallet..listen to mad dog..he knows..
    gwgillplumbingandheating.com
