Munchkin + Tekmar 270
coreys
coreys Member Posts: 27
Project involves redesigning zoning and adding outdoor reset scheme.
This is a Munchkin 140M currently setup with a simple fixed output temperature.
I would like to use a Tekmar Boiler Control 270 to modulate the Munchkin.
Anyone know if this can be done? If so, would it require an upgrade to the 925 controller card?
A lot of Munchkin fans on this board, so sometimes even obscure questions like this one will find an expert...
  • jerry scharf_3
    jerry scharf_3 Member Posts: 419
    upgrade to the munchkin
    I believe you need a rev 4 version of the 925, and an external interface box (often referred to as a tekmar interface) from HTP to be able to get what you want.
    jerry
  • Guy_6
    Guy_6 Member Posts: 450
    Munchkin
    The Munchkin modulates all by itself, by monitoring the delta between supply and return water.
    If you are looking for outdoor re-set capability I would suggest going with the Munchkin Vision 1 program. It was designed for the Munchkin, and is simple to install.
    There is a Tekmar interface available for the Munchkin as well, as Tekmar is certainly in the forefront of that technology.
  • coreys
    Thanks Guy.
    When I said "modulate", I suppose what I really mean is dynamically setting the output temperature (thus causing the boiler's brain to modulate the burner accordingly).
    I believe that 'interface' bit you speak of is the missing link.
  • coreys
    Thanks Jerry.
    That's a lead I can use.
  • jerry scharf_3
    more than just the box
    CH,
    reread my post. Older versions of the 925 software do not support the tekmar interface.
    jerry
