Myriad of problems with single pipe steam heat
Bob Metzger
Member Posts: 1
I have alot problems with my residential home single pipe steam heating system. I have a oil fired burner and a brand new boiler but I have 1) very bad water hammer, 2) oily & dirty water (lots of it) coming from the steam vents of each radiator during the beginning part of the heating cycle and 3) the radiators at the ends of runs not heating or not heating enough by the end of the heating cycle.
I have shimmed the radiators properly, experimented with various steam vents, put a level on every pipe to make sure the pitch is correct. I've had some less-than-informed heating/plumbing guys come in and scratch their heads over my steam heat problems which they have not been able to solve. I need a flat out ace expert at single pipe steam heating residential problems to come in here and sort it all out. I'm in Waltham, just west of Boston, Mass. Can you recommend someone who it really knowledgeable and sharp in this field and does business in my locale? This is an advanced problem and I need an expert. Thanks.
Easy, just use the Find a Professional search feature on the main menu. Sounds like your new boiler didn't get skimmed.0 -
Listen to Bob............................
You've got a few to choose from I believe. Scott Milne can handle that to. Mad Dog
steam help
Hi I am in Watertown
- 86.9K THE MAIN WALL
- 57 Biomass
- 109 Chimneys & Flues
- 5.7K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 973 Plumbing
- 6.3K Radiant Heating
- 386 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
