steam vsbaseboard
paul_51
Member Posts: 4
which system is more efficient steam or baseboard hot water? which is more maintaince free?
thanks
thanks
About the same
assuming both systems are set up properly, and have similar boilers. Certainly not enough difference to justify tearing out the steam. Also, steam has the advantage that the radiators and most of the piping drain dry when the system is off, so they won't freeze and burst if the power fails.
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
