One pipe radiator removal
Jim Bennett
Member Posts: 607
> I am trying to replace some valves on my one pipe <BR>
> steam system. I have the new ones, but the <BR>
> current setup is a little different. The old <BR>
> valves are fastened to the riser normally, but <BR>
> where the 90 degree exits towards the radiator, <BR>
> it has a pipe going directly into both the valve <BR>
> and the radiator. On the radiator side, it goes <BR>
> into a flange. It would seem the only way to have <BR>
> done this is for one of the components to have <BR>
> reverse threads. Since I don't want to break <BR>
> anything, any help is appreciated. About half my <BR>
> radiators seem to be set up this way, probably <BR>
> original (1912 house).<BR>
> <BR>
> Thanks. <BR>
<BR>
> <BR>
> Thanks. <BR>
<BR>
I am trying to replace some valves on my one pipe steam system. I have the new ones, but the current setup is a little different. The old valves are fastened to the riser normally, but where the 90 degree exits towards the radiator, it has a pipe going directly into both the valve and the radiator. On the radiator side, it goes into a flange. It would seem the only way to have done this is for one of the components to have reverse threads. Since I don't want to break anything, any help is appreciated. About half my radiators seem to be set up this way, probably original (1912 house).
Thanks.0 -
Rad valve.
There's no union nut on the old valve? Can you post a picture?There was an error rendering this rich post.
no union
probably a left right nipple and coupling0 -
l. & r.
probably a left & right bushing. replace with ips 2 " x 1 1/4 " bush.0 -
If it's a left/right nipple, from which direction would I turn to loosen? From what perspective?
Thanks.0 -
el sliceo
slice out the whole shebang with your trusty sawzall and then replace valve & bushing0
- 87.5K THE MAIN WALL
- 123 Chimneys & Flues
- 118 Geothermal
- 15.9K Strictly Steam
- 57 Water Quality
