any one familliar with these?
Kirk_2
Kirk_2 Member Posts: 1
Any one fammiliar with the "Rex Solution"These are stainless steel indirect water heaters.Manufactured,byAICOO.
They are used to heat domestic hot water,in commercial buildings.They say,no storage tanks,are needed for hot water.A boiler would circulate and heat,the water in the tank shell.The cold water,enters the tank botom,and flows thru spiral coils(lots of them)and is heated,by the tank
water,and flows thru and out of the tank,to the buildin.as hot water.
Just curious,if any one has installed these/any problems/or things to look out for?
thank you
Harsiwilianto
  • Somethiing Else
    Somethiing Else Member Posts: 10
    Indirect
    Many boiler manufacturers offer these as an optiion with thier equipment. either steel or Stainles steel. Some have a coil within the tank or some have a tank within a tank. Another option is a coil inside of the boiler
