gas water heater in garage
WPH2205
WPH2205 Member Posts: 52
Does anyone out there know if there has been a revision in the code which states that a gas water heater installed in a garage must be a minimum of 18" off the floor? The reason I ask is because of the new "flame arrestor" design. I have a job where the existing direct vent water heater is leaking and I want to replace it with an atmospheric heater and power venter. Problem is I don't have the 18" to raise it. Any suggestions? thanks.
