Hoffman boiler return trap
gerry gill
gerry gill Member Posts: 3,078
and install a vaporstat..unless you have a coal boiler its not needed..and where does the parallel to the boiler feed pump come from? different functions entirely.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=360&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
gwgillplumbingandheating.com
  • captbuderus
    captbuderus Member Posts: 10
    I know parts are not available, but I have a unit that functions except that the motive steam side leaks. It pressurizes the trap not allowing condensate back properly. Are they repairable? (Cleaning seat and surface) Does anyone have any parts? I will replace with a boiler feed pump if I can't repair unit.
  • Brad White_9
    Brad White_9 Member Posts: 2,440
    Did you check Tunstall Associates?
    You may not find factory original parts but maybe you can get current parts that are just as good as the originals.
    http://www.tunstall-inc.com
  • captbuderus
    boiler return trap
    No dice with Tunstall. Any other ideas?
  • Christian Egli_2
    Christian Egli_2 Member Posts: 812
    New found value
    Everything is repairable, particularly with steam since these systems have very few moving parts. And it isn't like the electronic components you can't do much else about but mourn.
    I find repairing is often less costly than refitting a new. We do it all the time with every system we own. Steam has incredible value.
    If you really need the return trap (by Gerry Gill's vaporstat suggestion) Armstrong and many other manufacturers still make mini pumpless condensate pumping traps.
    And if you need repair work, I would be happy to help. We can discuss this further if you want. It won't be as costly as a new pumping trap or a new condensate electric pump installation. -We have a machine shop in Ohio.
  • gerry gill
    Hey Christian
    where in ohio are you? i'm up in bedford, by cleveland..i've had machining needs in the past and really had no where to turn.. no-one wants to do a small job..we'll have to get together and talk steam someday.
  • captbuderus
    return trap vs feed pump
    If I can't fix/repair the original boier return trap, I would install a boiler feed pump/receiver/control to return condensate to the boiler. Vaporstat may be worth a try. I will need to get the condensate out of the return syatem
  • gerry gill
    why won't the condensate
    return by itself? it did before..all the return trap did was push on it if the boiler pressure got to high..was usefull before invention of the vaporstat.
