help
IN relationship to what you've said, where is the pump located?
Also, did he use some sort of air seperator/scoop?
Is the pressure staing steady? Is the relief valve showing any signs of leakage?
ME
  • This content has been removed.
  • bob young
    bob young Member Posts: 2,177
    PURGE STATIONS
    THREE ZONES YOU NEED THREE RETURNS CONNECTED TO A COMMON PROPERLY SIZED RETURN HEADER WITH PURGING PROVISIONS FOR EACH ZONE.
