piping
ernie_3
Member Posts: 191
piping, black iron.......dope.....wickum or expando?
If You Don't Want it to Leak ....
Use wick & dope for water.Except stand pipes.0 -
permatex
you only want to install it once-----permatex0 -
4\" plus sizes
Why not gruvlok or welded?0 -
new ways
i am from the old school & love working with pipe but threaded pipe over 2" is fast becoming a thing of the past. welded & victolic is the way to go. far less headaches and risk. get a bad fitting or leak on a 4 " joint can cost you labor that can't be recovered. can make a marginal job a loser.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
