rusted nuts and studs
ed wallace
Member Posts: 1,612
I have to replace a motor on a condensate tank thats in a pit the motor was under water for an unknown time I was wondering if i can replace the steel nuts with brass nuts just seems like it will be easier to disassemble in the future especially if the sump pump thats in the pit fails again
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=354&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Maybe try
silicon bronze hardware from a marine supply house, or comparable 304 or 18/10 stainless steel hardware? Brass strikes me as being too soft if you have to torque them. And use stainless washers underneath the heads, I would think.0 -
Never seize !
Buy some and put it on anything that will ever have to come apart. I like the copper based ones. They seem to take the heat a bit better. I swear by it. Chris0
- 86.7K THE MAIN WALL
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 939 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
