Radiant Baseboard with Standard Water Heater?
Jake B_2
Member Posts: 2
Hello
I'd like to know if you've any info on how to make baseboard heaters work off my existing hot water system?
I have a 1K sq ft house, and there's gas heat in all the public areas but none in the bedrooms. Which leaves me with only 2 10X10 rooms I'd like to heat, so i'd prefer not to have 2 seperate systems.
Thanks,
Jake
Thanks,
Jake
Rescom
is the mane of a company that makes radiant baseboard that allows potable water in ther system , do a heat load caculation on the rooms and see home much you will need0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
