Cast iron vs. bronze?
hr
Member Posts: 6,106
system with barrier tube, if it has pex, cast should be fine.
Although I am a proponent of hydronic conditioners regardless :)
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
hot rod
cast iron vs. bronze circulator
Which material is apprioprate for use in hydronic heat loop?0 -
It's a closed loop
with copper (baseboard). But your reply has reminded me of an obvious answer I should have thought of to begin with... better to use bronze circ. with the copper pipe.0 -
Bronze for pottable water
Waste of money on a closed loop. No oyxgen, no rust.0 -
C.I.
C I it is
Thanks for your help!
Johnny0
- 87K THE MAIN WALL
- 57 Biomass
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 986 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
