Best Replacement Heating System??
Sheri
Member Posts: 2
Does direct-vent always mean using an outside wall? Sounds like a wall furnace is the right idea but the space available for it is on an interior wall and I don't think there is a choice about it.
My old propane furnace died yesterday. My propane guy is perfectly willing to replace it with a duplicate model but...I was hoping to find a smaller unit to do the same job and he isn't offering up any suggestions. All I need is a propane heater with a blower to warm a small space (1000 sq. ft) that stays pretty warm as it is. I am imagining something wall mounted, maybe analogous to what an on-demand water heater looks like. Any ideas?0 -
First do a heat-loss calculation
to see how much heat you actually need. You can get the software by clicking on "Free Heat Loss Calcs" link at the upper left. Then use that to determine how big a unit you need.
gas wall heaters
Whatever you get, make sure it's direct vent. Look at Monitor and Cozy they have nice units.
www.monitorproducts.com
www.cozyheaters.com0 -
Wall Heaters
Stay away from units that use an ECO switch as a safety. They can be EXTREMELY unreliable. your salesman should be familiar with what I mean. If he isn't, keep shopping.0 -
go to www.ductlessheating.com
Do your heat loss in the "heat selector" section. I would think the Rinnai 1004 will do the trick for you. Best technology and reliability in the catagory.0 -
some wall heaters
offer a top mounted flue. You vent up through the wall stud cavity and out the roof. Look at Empire heaters also.0
- 87.1K THE MAIN WALL
- 117 Chimneys & Flues
- 5.7K Gas Heating
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
- 49 Job Opportunities
